Samsung PS42V4SX
Discussion in 'Plasma TVs' started by Hicksy, Jul 27, 2004.
  1. Hicksy
    Hicksy
    Does anybody own a Samsung PS42V4SX?
    j
  2. naaz
    naaz
    Aug 15, 2004
    32
    Hi Hicksy
    Did you get any answer for the Samsung PS42V4SX as I also would like to buy one but have had no luck with reviews.
    Please let me know.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    is it a plasma? if so and it costs more than £1800 its probably not worth the money.
  4. sreid
    sreid
    I have one. I am curious as to why it's not worth the money over £1800.00 though.
    Shaun
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    cause for £2k you can buy a Panny PW6, just a bare screen but still the best on the market at under £3k
  6. sreid
    sreid
    So how much would it have been with a tv tuner, pair of speakers a tv stand and input board. 2K would have bought a blank screen, but I didn't just want a blank screen and didin't have 2K. I bought it cause for the money I had it fitted everything I wanted and had a couple of recommendations from this board as well. Is the samsung worth the money, well if it's all you can afford yes. Is the panny worth the money, no, not if you don't have it. For £1800 or a little over what would you have suggested I should have went for bearing in mind that's my top limit.
    Shaun
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Thats no problem shaun and i hope you are happy with your purchase, TV tuner £50 freeview box, Desktop stands are £160 ish and speakers (most people round here have surround sound systems already) £200making it£2400 for what you would require, but if you can afford the extra or just need a plain screen it is worth the extra.
  8. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    For £1729 inc delivery the Samsung looks good value for money
    especially if Samsung are giving a 2 year guarantee
    (like they do in every other country)
    I agree the Panasonic works out at least £2200+ with stand, twin tuner, SCART & composite inputs. Thats almost £500 more!
  9. naaz
    naaz
    Aug 15, 2004
    32
    Hi Shaun
    You say you own a Samsung PS42v4SX if so please give me your true opinon if it is worth the money or not really. Give it to me straight.
    Regards
    Naaz
  10. Hicksy
    Hicksy
    well i can give it to you straight......yes it is worth buying one. (i have one)
  11. dogma6
    dogma6
    Aug 20, 2003
    217
    +14
    Hi Hicksy,
    Can I ask what its like when watching the footy?, is it an acceptable picture? no blurring etc. I know a lot of it will probably come down to the source your using, I'll be using Sky+ via Scart & Freeview via component.
    I'm gonna be buying a plasma in the next 2wks , going for the panny @ the moment but the samsung does look like a very good deal :)
    I'll be using scart & component connections which I believe the samsung has.
    thanks for your help :clap:
    Mark
  12. Hicksy
    Hicksy
    Footy has got better since i have had it. I mean, it doesn't compare to my tosh crt. However i run it through telewest using a normal scart lead so no doubt it can be improved.
    Still very happy and it has component, scart and Dvdi connections.
    Its also a generation 4 display.
    WOuld you say scart to component is better than scart to scart from my telewest digital?
