Samsung PS42V4SX - Any opinions?
Discussion in 'Samsung TVs Forum' started by LIMMOZINNO, Jul 1, 2004.
  1. LIMMOZINNO
    LIMMOZINNO
    Was wondering if anyone had any opinions on the new Samsung PS42V4SX?
    At £1850 it seems a bargain. 3000:1 contrast ratio, built in tuner, including stand and speakers, 2 scart sockets.....
    I plan to use it as a normal TV with an XBOX hooked up. Possibly with a lot of DVD usage.
    Opinions greatly received.
    L.
  2. bert2
    bert2
    Jul 2, 2004
    98
    Leominster
    +3
    Have you seen it or just heard about it? I assume it is in Currys or Comet who have a good returns policy if you get it home and are not satisfied.
    You need to make up your own mind. Take your XBOX and a DVD you know to the shop and try it. If that is OK and the TV picture is OK for you in the shop, or they will agree that you can bring it back if it is not satisfatory at home, then why look further?
  3. LIMMOZINNO
    LIMMOZINNO
    True, true...
    It seems to be offered only by online shops at the moment though. Here is a link to pricerunner, where the model has just shown up on my 'radar'...
    http://uk.pricerunner.com/sound-and-vision/vision/tv/215466/details
    I was looking very closely at the Hitachi 5200 and the Panny DW6 or PA20, but this Samsung seems to have everything (speakers, tuner, stand, 2 scarts etc...) for only £1850.
    Methinks I am missing something - or maybe it is just good value.
  4. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Did a quick search on the Samsung site and I can only find the plasma available in one other country...Sweden.
    Specs are not on the UK site but they are on the Swedish site
    Any one swedish to translate this?
    Specifikationer
    Bildskärm
    Display : Plasma
    Upplösning : 852(H) x 480(V)
    Ljusstyrka, kontrast : 1000cd/m2, 3000:1
    Antal färger (gråskalor) : 1,677 Million Color( 256 levels)
    Bildformat : 16:9
    Pixel Pitch : 1.095*1.110
    Viewing angle (Degrees) : 160 grader( H / V)
    Scan system : Progressive
    Digital Comb Filter : 4H Digital
    Brusreducering : Digital Noise Reduction (DNR)
    Ljud
    Uteffekt (Watt) : 2X15W
    Stereo : Nicam, SRS TruSurround XT
    BIB-funktioner
    BIB storlekar : Large, Small, Double
    Features
    Tuning system : Auto/PAL/SECAM
    Kylsystem : Utan fläkt
    Bildförbättringsalgoritm : DNIe
    Auto Pixel Shift (inbränningsskydd) : Ja
    Plug & Play : Ja
    TextTV minne (antal sidor) : 2100 sidor
    Auto Power OFF : Ja ( efter 15 minuter)
    Av/På Timer : Ja
    Insomningstimer : Ja (Max 360 min)
    Barnlås : Ja
    PC Signal : Nej
    Stillbild : Ja
    Ingångar
    Scart : Ja, 2 st
    Audio : Ja
    S-Video In : Ja
    Video In : Ja
    PC-ingång : Nej
    Antenningång: Ja
    Utgångar
    Monitor out
    Generellt
    Strömförsörjning : 100¨~260V Free Voltage (50/60Hz)
    Energiförbrukning / Stand-By : 330W / <3W
    Mått (W*H*D) : 1027*631*79
    Vikt : 31kg
    Bordstativ ingår
  5. YahooSerious
    YahooSerious
    There you go.
    -Yahoo
    I'm not Swedish btw, from Norway :p
