Samsung PS42S5H and PS42S5S don't support 720p over component ???
Discussion in 'Samsung TVs Forum' started by dagmaniac, Jul 20, 2005.
  1. dagmaniac
    dagmaniac
    I wanted to buy one of these, so I downloaded the manuals. Was already set for a nice long drive into Germany next week, cash burning a hole in my pocket.
    According to pg. 57, the Samsungs don't support 720p over the component in.
    Can anyone confirm this ?
  2. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
    Hmm, I was going to buy this TV too, but you're right. In the manual I downloaded, it's on page 61, and it says:
    I'm pretty sure 720p is supported, but i would like to be sure before spending £1,500!
  3. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
    It says this on the PC page tho:
  4. busdriver2000
    busdriver2000
    May 22, 2005
    79
    harrogate
    works fine over component on my moded xbox and dvdrecorder ,go for it you wont be disappointed :lesson:
  5. dagmaniac
    dagmaniac
    Aaaah, that's what I wanted to hear :)
  6. Ponty
    Ponty
    Feb 15, 2005
    68
    Are we sure, I'm in the same boat and about to buy?
    Would like to get clarification before hand...
  7. GeorgePk
    GeorgePk
    Mar 12, 2005
    75
    Nicosia
    +4
    I would appreciate if you gave us the link to the manual you refer to
  8. Gussie
    Gussie
    Oct 19, 2004
    1,237
    48
    +79
    Try using the SEARCH function ??? :lesson:
    Gussie :)
  9. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
  10. clarky78
    clarky78
    Nov 8, 2004
    1,879
    Helsinki, Finland
    +41
    The people who say "try using the search function" should just ignore the damn thread if it bothers them that much. They obviously don't use it or they'd know you have to trawl through hours of info for a simple answer. This has to be my only gripe with this whole forum..!!
    Rant over...
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    very few DVD recorders output 720p are you sure it handles 720p not just vanilla 480i/p or 576i/p and is this at both 50 and 60Hz?
  12. Gussie
    Gussie
    Oct 19, 2004
    1,237
    48
    +79
  13. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    Any chance of some constructive comments on usage of the search function, then, like the queries you used or links to the results you found?
    I recall the German forummer (Blarney?) who bought one of these saying he'd got 720p50 working, I think...
    EDIT (found the post)
    See here: http://www.avforums.com/forums/showthread.php?p=1771838#post1771838
  14. nheather
    nheather
    Oct 6, 2004
    17,468
    167
    Horsham, West Sussex
    +6,829
    I've just downloaded the United Kingdom version of the manual from the Dutch website and it says very little about screen resolutions.
    The only reference it makes to them that I could see is for the computer input. For this it does say that 720P is not supported (I wouldn't expect it to be - 768 yes, but not 720).
    I'll have a look at the other english language manuals marked Europe.
    Cheers,
    Nigel
  15. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
    Um, I QUOTED the actual piece of text and gave you the page number it was on that clearly OMITS 720p as a capability of this screen OVER COMPONENT.
    As for searching, you don't need to search the entire forum anymore... any thread has a search this thread button. There are only about 5 threads about the new samsung so far. I found the manual by searching the threads, so it can be done!
    The Xbox comment could have been using 720p, which is available to some games and stuff like the XBMC.
  16. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
    Well, I don't think it could call itself a HD screen if it didn't take 720p over HDMI. It's component we're worried about.
  17. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,351
    +812
    If the screen is described as "HD Ready" it has to accept 720/50p and 720/60p via both component analogue AND HDMI inputs, as well as 1080/60i and 1080/50i via the same inputs.
    If the set is NOT described as HD Ready then it is likely that it doesn't support all modes via both inputs, or doesn't support HDCP.
    Is the set described as "HD Ready" and accompanied by the logo?
  18. Chavvychase
    Chavvychase
    The 5H has the HD ready logo on the front (on the pedestal)
  19. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Well, as long as they are being truthful, it will accept HD on component. TBH it's more likely that they have not bothered to put it in the spec than have actually not implemented it. LG are the same, not very good at blowing their own trumpet on the stuff that matters. They are better at sounding off with meaningless numbers, like 10 000:1. They've never been poor on connectivity, I'd expect it to work.
  20. nheather
    nheather
    Oct 6, 2004
    17,468
    167
    +6,829
    Not saying they have done this at all, but surely they can use the HD ready logo if the HDMI input supports it even if the component input does not.
    After all component is not an HD input as it does not have HDCP.
    Cheers,
    Nigel
  21. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No, the standard is for HD on component and HDMI. You carry the badge if you fulfil this, and have at least 720 vertical resolution.
  22. craigae
    craigae
    Oct 6, 2003
    636
    28
    +89
    Well that's that sorted then :)
  23. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    In theory, anyway.
  24. nheather
    nheather
    Oct 6, 2004
    17,468
    167
    +6,829
    But a component input can't handle HDCP protected material can it?
    Does this mean that HD Ready does not require HDCP support?
    Cheers,
    Nigel
  25. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    HDCP is only carried on digital signals, not analogue component.
    Steve
  26. Bill_Abz
    Bill_Abz
    Feb 28, 2005
    24
    3
    Aberdeen
    I've recently bough the ps42s5h and a Samsung DVD850 and am happily running 720p over component. (I wasn't willing to pay Comet £90 for an HDMI cable!, so waiting for one to arrive). I've tried 576P/720P/768P (Nice native res for the panel) and 1080i all on component.
    Hope this helps.
    Bill.
  27. tjradiohead
    tjradiohead
    Jul 29, 2005
    4,036
    71
    +58
    Any more on this? anyone ordered this panel and had good results/problems at 720p?
