Samsung ps42d4sxx £998
Discussion in 'Plasma TVs' started by pixelpidgeon, May 21, 2005.
  1. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,287
    +711
    Hi.
    Is this a good deal for last in store?
    Got them to hook it up with components to a prog scan dvd in store.
    this improved the dvd picture somewhat. but maybe not as much as i might have expected. i have read on here that with this model plasma, the 'special' screen settings should not be used. I am new to the world of plasma screens. i am looking to invest in a good screen. Is this a good price? i know this isnt the latest and greatest of plasmas, and samsung dont get talked about on here as much as the pioneers & panasonics, but for value for money would £998 be a good deal?
    Thanks, Graham :)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    thats £350 less than a PWD7 is a PWD7 worth the extra £350? if you are not 100% happy with the PQ then dont rush to buy it. If you are then go ahead but £1000 is a lot of money to look at every day regretfully (if you get it home and think "oh well it was only £998 it isnt that bad i suppose" you have bought the wrong product you should think "wow that is bloody fanatstic" ....................
  3. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,287
    +711
    hehe.. thats wierd i was just looking at this
    http://www.av-sales.co.uk/plasma/html/panasonic_th-42pwd7bs.html
    just abit put off my lack of plasma knowledge. in this case. inputs/outputs.
    i have a sky free to air box. scart out. and also rs232??... also have a denon 500SD cinema system, and xbox. (the usual bunch).
    Anyone know what i will need to connect all to eachother?
    i mean, the link above shows both these as options for £55:
    BNC Component/SVHS/Composite
    Dual Slot Terminal Board
    Scart Terminal Board
    thanks, Graham
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    persoanlly i would get a daul slot board for denon and spare S-video/composite input, component board for Xbox and add a JS RGB>VGA for sky (there are other ways, could convert it all to compoent and use a switcher with just the one board etc)
    PWD7, mount, Dual slot board, extra component board (BNC) and JS RGB>VGA
    Total Including UK TAX (17.5%) & Delivery to UK mainland: £ 1,612.88
  5. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,287
    +711
    thanks alot for your help! suppose now its just a matter of going with the panasonic or the new Samsung...
    http://www.digiuk.com/productdetail.asp?id=4189
    think i will steer clear of the end-of-line bargain route now.
    cheers, Graham
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    graham keep an eye on the price of the PWD7 while doing this try and get some demos in and work on your connection options!!!
  7. pixelpidgeon
    pixelpidgeon
    May 5, 2005
    3,287
    +711
    will do. and thanks again for your help. :rotfl:
  8. Ricey155
    Ricey155
    May 23, 2005
    17
    3
    the samsung has a good picture, but not the best
    im totally unsure what to buy even more today
