Samsung PS42A457P1D and DVD-R155 Sync probs
Discussion in 'Samsung TVs Forum' started by johna456, Jun 15, 2009.
  1. johna456
    johna456
    Oct 29, 2008
    11
    I have a Samsung plasma 42inch PS42A457P1D and a samsung DVD-R155 dvd recorder, i have it hooked up by hdmi lead and a opitcal lead from dvd into a technics 5.1 amp. now when i'm playing original dvd's some times the mouths are out of sync. I've looked in both manuals and tried looking on the net for the answer to sorting this out without luck.
    Can anyone help thanks
  2. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    the issue will be between the dvd an the amp
    If youre amp doesnt have an audio delay feature (check youre manual) the only way you can remedy it is normally by stopping/pausing the the dvd and then resuming
    regards
  3. johna456
    johna456
    Oct 29, 2008
    11
    Thank's, i'll have a look at the amp, only thing i havn't looked at so it must be that.
