Samsung PS-P42P3S Help!
Discussion in 'Samsung TVs Forum' started by bluefish, Aug 5, 2004.
  1. bluefish
    bluefish
    Mar 5, 2003
    37
    Ireland
    My Plasma started making noises large buzzing noises so as it was under warranty I received a replacement screen while they try to fix mine.
    I received the ps -p42p3s (which is the new version of my plasma), the problem is that I am trying to connect it to my Iscan Ultra using a VGA (15 pin pc connection) which is how I connected up the old plasma with no difficulties, but all I am getting is flickering. When I connect using scart or an other connections I have no problem but obviously the picture isnt as good as it would be with the Iscan! :confused:
    I would appreciate any thoughts any of you had (even with the limited info I have provided)
    Bluefish
    P.S I have it connected as follows:
    Philips DVDR recorder scart out to JS Technology RGB to Component (YUV) Converter to Iscan Ultra via component to finally Samsung ps-42p3s using vga (15 pin pc connection)
