SAMSUNG PS-50Q96HD sound problem?
ayubars
Hi Guys,
i heard this product has sound problems? Has anyone encountered them? I heard if you put the volume high, the sound can be a little distorted? Not too sure? Has anyone had this problem? I have a sony 44" projector and so far this has been the best TV for sound so far.
kbfern
Only problem regarding the sound is occasional dropouts when using on board freeview,I believe this has been cured with a firware upgrade which can be done over the air.
As far as the general quality of sound is concerned the tv is poor,but not significantly worse than most large screen tv's.The set has an incredibly good picture for the money sd and especially hd pictures.
I always route my sound through my av system anyway so the onboard sound does not bother me.I can't see much reason for buying a 50" tv and then listening to the puny onboard speakers.:)
Ill second that...The onboard speakers are poor to say the least.
ayubars
Thanks for you replies guys.
So can i still use the onboard sound? I just don't want to go about buying more things and cluttering the living room. Can the onboard sound be acceptable for SKY plus and normal DVD movies? And also when i hook up the laptop?
many thanks
kbfern
Depends what you call acceptable,to me no,but I like good quality sound.
Only you can tell if its any good for you.Take a trip up your local currys/comet today if I were you and have a quick listen to satisfy yourself.
ayubars
YEs,
thanks i think i will do that. The TV is set for delivery on Sunday so if im not too impressed then i should still be able to cancel.
thanks a million.:)
many thanks
Its ok for the soaps etc when the misses is watching it but you should really think about buying a av amp or an all in the box setup to really enjoy your big screen :smashin:
