H
HMMZ944
I have played a little bit with the service menu and now i want to reset the settings. The firmware is 1018 can anyone send me the original settings. To make it easyer for you I put the data of firmware 1008 in this message but the 1018 is a little bit differnt you had to do about 10 extensions.
If it is possible I need Data from a german PS 42S5H.
SERVICE MODE: (im Standby) INFO-MENU-MUTE-POWER
T-PCN42PEUH-1008
Sub Micom Ver-1005
MAY 19 2005 17:11:56
===== MENU 1: CALIBRATION =====
AV Calibration
DTV Calibration
PC Calibration
===== MENU 2: OPTION CABLE =====
Panel Option 42S5H
Gamma Mode2
Analog Dimming Mode3
Auto Power ON
Key Lock OFF
DDC Write OFF
LNA ON
Ant. GAIN Display OFF
Language English
Auto FM ON
High Deviation OFF
TTX ON
TTX List Flop
TTX TOP OFF
TTX Group Auto Language
TTX Level Level 15
Shift Test OFF
Sound Delay 1 OFF
Sound Delay 2 OFF
DEBUG OFF
===== MENU 3: WHITE BALANCE =====
Sub Brightness 106
R-Offset 122
G-Offset 128
B-Offset 114
Sub Contrast 30
R-Gain 120
G-Gain 128
B-Gain 145
===== MENU 4: SVP-EX (DCRe, Trident 10-bit video processor ?) =====
Comb Filter 80H
Peaking/LTI ------------------------->
LTI_gain 0CH
Lowpass_gain 0AH
Bandpass_gain 1CH
Highpass_gain 0EH
Coring_TH 02H
Peaking_pos_gain 01H
Peaking_neg_gain 0CH
VSharp_neg_gain 04H
VSharp_pos_gain 02H
NR ---------------------------------->
Y_NR_OFF 80H
C_NR_OFF 80H
Y_NR_ON 80H
C_NR_ON 80H
Deinterlace ------------------------->
Motion 80H
Picture Gain Adjust ------------------>
TCD3 Contrast 7CH
TCD3 Brightness 1CH
TCD3 CR 80H
TCD3 CB 80H
TCD3 Delay 00H
Analog Y Offset 40H
Analog Pb Offset 80H
Analog Pr Offset 80H
Analog Y Gain D6H
Analog Pb Gain FEH
Analog Pr Gain FEH
Black Level 00H
SVP Brightness 00H
User Colormax 00H
===== MENU 5: SAA7119 (made by Philips, maybe?) =====
HTC 2
ATVT 1
LUFI 5
NAICO_BRIG 112
NAICO_CONT 65
NAICO_SATU 64
NAICO_HUE 0
COMP_BRIG 114
COMP_CONT 62
COMP_SATU 64
TASKA_BRIG 140
TASKA_CONT 64
TASKA_SATU 64
LIMOD 0
LIFIL 2
LIWGT 0
===== MENU 6: MSP34XX/44XX =====
FM-PRESCALE 20H
NT-M-PRESCALE 20H
SECAM-L-PRESCALE 22H
AV-PRESCALE 1AH
I2S_1 PRESCALE 10H
I2S_2 PRESCALE 10H
CARRIER MUTE 42H
PILOT HIGH 0EH
PILOT LOW 07H
===== MENU 7: YC DELAY =====
RF PAL-B/G 102
RF PAL-D/K 102
RF PAL-I 102
RF SECAM-B/G 34
RF SECAM-D/K 17
RF SECAM-L/L' 17
RF NTSC 3.58 187
RF NTSC 4.43 187
AV PAL 67
AV SECAM 34
AV NTSC 3.58 102
AV NTSC 4.43 102
AV PAL60 119
===== MENU 8: ADJUST =====
VIDEO MUTE TIME 10
MELODY VOLUME 5
ANA_DIMM_MAX FEH
TTX CONTRAST 50
TTX BRIGHTNESS 50
TTX COLOR 50
DYNAMIC CONTRAST 100
DYNAMIC COLOR 50
DYNAMIC SHARPNESS 60
STANDARD CONTRAST 90
STANDARD BRIGHTNESS 80
STANDARD COLOR 70
STANDARD SHARPNESS 70
MOVIE CONTRAST 60
MOVIE BRIGHTNESS 50
MOVIE COLOR 50
MOVIE SHARPNESS 40
RF_dB_1 0
RF_dB_2 0
RF_dB_3 0
===== MENU 9: DNIe =====
PATT_SEL 0
BLACK_TILT 120
BLACK_GAINMAX 95
TEST_MCC 0
OVERLAP_MCM 0
AREA_EN_MCC 31
R-OFFSET 0
G-OFFSET 0
B-OFFSET 0
R-GAIN 128
G-GAIN 128
B-GAIN 128
COM_OFFSET_SEL 1
COM_GAIN_SEL 1
MCM_EN 1
TEMP_DEST 150
CB5_HIGH 152
CR5_HIGH 131
CB5_LOW 126
CR5_LOW 128
===== MENU 10: CHIP DEBUGGER: OFF =====
===== MENU 11: CHECKSUM =====
===== MENU 12: RESET =====
===== MENU 13: SPREAD SPECTRUM =====
===== MENU 14: LOGIC =====
INT/EXT SEL 0
PAT SEL 0
FCRL CON 0
IMAGE STICKING 0
ERROR MODE CHECK 0
ERROR MODE TABLE 0
Vs REFERENCE 0
Vs AVERAGE 0
Vs to D/A 0
Va REFERENCE 0
Va AVERAGE 0
Va to D/A 0
T-PCN42PEUH-1008
Sub Micom Ver-1005
AV Calibration
DTV Calibration
PC Calibration
Panel Option 42S5H
Gamma Mode2
Auto Power ON
Key Lock OFF
DDC Write OFF
LNA ON
Language English
Auto FM ON
High Deviation OFF
TTX ON
TTX List Flop
TTX TOP OFF
TTX Level Level 15
Shift Test OFF
Sound Delay 1 OFF
Sound Delay 2 OFF
DEBUG OFF
Sub Brightness 106
R-Offset 122
G-Offset 128
B-Offset 114
Sub Contrast 30
R-Gain 120
G-Gain 128
B-Gain 145
Comb Filter 80H
LTI_gain 0CH
Lowpass_gain 0AH
Bandpass_gain 1CH
Highpass_gain 0EH
Coring_TH 02H
VSharp_neg_gain 04H
VSharp_pos_gain 02H
Y_NR_OFF 80H
C_NR_OFF 80H
Y_NR_ON 80H
C_NR_ON 80H
Motion 80H
TCD3 Contrast 7CH
TCD3 Brightness 1CH
TCD3 CR 80H
TCD3 CB 80H
TCD3 Delay 00H
Analog Y Offset 40H
Analog Y Gain D6H
Analog Pb Gain FEH
Analog Pr Gain FEH
Black Level 00H
SVP Brightness 00H
User Colormax 00H
HTC 2
ATVT 1
LUFI 5
NAICO_BRIG 112
NAICO_CONT 65
NAICO_SATU 64
NAICO_HUE 0
COMP_BRIG 114
COMP_CONT 62
COMP_SATU 64
TASKA_BRIG 140
TASKA_CONT 64
TASKA_SATU 64
LIMOD 0
LIFIL 2
LIWGT 0
FM-PRESCALE 20H
NT-M-PRESCALE 20H
AV-PRESCALE 1AH
I2S_1 PRESCALE 10H
I2S_2 PRESCALE 10H
CARRIER MUTE 42H
PILOT HIGH 0EH
PILOT LOW 07H
RF PAL-B/G 102
RF PAL-D/K 102
RF PAL-I 102
RF SECAM-B/G 34
RF SECAM-D/K 17
RF SECAM-L/L' 17
RF NTSC 3.58 187
RF NTSC 4.43 187
AV PAL 67
AV SECAM 34
AV NTSC 3.58 102
AV NTSC 4.43 102
AV PAL60 119
VIDEO MUTE TIME 10
MELODY VOLUME 5
ANA_DIMM_MAX FEH
TTX CONTRAST 50
TTX BRIGHTNESS 50
TTX COLOR 50
DYNAMIC COLOR 50
STANDARD COLOR 70
MOVIE CONTRAST 60
MOVIE BRIGHTNESS 50
MOVIE COLOR 50
MOVIE SHARPNESS 40
RF_dB_1 0
RF_dB_2 0
RF_dB_3 0
PATT_SEL 0
BLACK_TILT 120
BLACK_GAINMAX 95
TEST_MCC 0
OVERLAP_MCM 0
AREA_EN_MCC 31
R-OFFSET 0
G-OFFSET 0
B-OFFSET 0
R-GAIN 128
G-GAIN 128
B-GAIN 128
COM_OFFSET_SEL 1
COM_GAIN_SEL 1
MCM_EN 1
TEMP_DEST 150
CB5_HIGH 152
CR5_HIGH 131
CB5_LOW 126
CR5_LOW 128
INT/EXT SEL 0
PAT SEL 0
FCRL CON 0
IMAGE STICKING 0
ERROR MODE CHECK 0
ERROR MODE TABLE 0
Vs REFERENCE 0
Vs AVERAGE 0
Vs to D/A 0
Va REFERENCE 0
Va AVERAGE 0
Va to D/A 0
