Samsung Plasma Panel 42" SDI V3 1024x768
Discussion in 'Samsung TVs Forum' started by Funkybase, Jul 23, 2004.
  1. Funkybase
    Funkybase
    Jul 21, 2004
    69
    I have found a HD-plasma in Sweden to a very reasonable price. It is based on the Samsung SDI V# 1024x768 panel. Does any one know anything about this korean panel? The price for this panel is approx. £2600.
    Spec
    Key Features
    - Screen Size : Diagonal 42"
    - Aspect Ratio : 16:9
    - Peak Brightness : 1000cd/§³ (V3)
    - Contrast Ratio : 3000:1 (V3)
    - Resolution : 1024 x 768 HD (XGA)
    - Displayable Colour : 16.7M
    - Auto Detection : NTSC/PAL/SECAM Auto Detection
    - Viewing Angle : Over 160deg.
    - PC Monitor support up to : 1280 x 1024 75Hz
    - Screen Format : Pillar, Full, Zoom1, Zoom2
    T V
    - Auto Channel Preset
    - Auto Channel Sort
    - Child Lock, Closed Caption
    - DTV System : Auto Detection For DTV Ready Signal
    - Advanced Motion Digital Porecessor
    - HD Signal De-Interacing
    - 3:2 Pull Down for Film Scan Conversion
    - Digital 3D Comb Filter
    - Digital Progressive Line Scaling
    - Favorite Channel Programming
    - PIP & PBP
    Connectivity
    - DVI Input : DVI-D/DVI HDCP
    - RGB : Mini D-Sub 15pin x 1
    - Component : RCA 3pin (support 480i, 480p, 720p, 1080i) x 1
    (Support 480i) x 1
    - S-Video : Mini Din 4pin x 1
    - AV1 (Composite 1), AV2 (Composite 2) : RCA 3pin x 2
    - RF : 2RF Ports(AIR/CATV)
    Control
    - OSD : Smart OSD with Images and High Quality Font
