Samsung Picture settings, help please.
Discussion in 'Samsung TVs Forum' started by carex, Mar 25, 2006.
Tags:
  1. carex
    carex
    Mar 29, 2005
    55
    9
    Hi Guys.
    Just bought the Sammy LE26R41B and I wonder what settings other people are using, I'm sure it must have been discussed before, so if somebody knows where the thread is, can they point me in the right direction:smashin:
  2. lance23
    lance23
    I use:
    Colour tone: normal
    Contrast: 75
    Brightness: 70
    Colour: 58
    Sharpness: 30 (doesn't matter what you have this on, makes no difference!)
  3. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    There are about 100 threads on this subject, The one thing that is obvious throughout is that each individual will have a different setting. This is because we may all like differing levels of colour, contrast, brightness etc.
    Colour is the worst one. Everyone percieves colour in a different way, not just on TV's but in life in general.
    The lesson learnt is..... just experiment until you get what YOU want. The out of the box settings on mine were not far from what i like.
    Good luck....:)
  4. carex
    carex
    Mar 29, 2005
    55
    9
    Cheers.
    What are people using in conjunction with a Sky box? ie... contrast: (low,medium, high.) RGB: (on,off)
    On a unrelated matter concerning the Samsung (new thread), just found out there's a time lag when using external speakers? (not in synchronisation) as anybody else had this problem
  5. lance23
    lance23
    Yep, i have this problem. It's nothing major and most of the time is easy to ignore.
  6. carex
    carex
    Mar 29, 2005
    55
    9
    Glad it's not just me then & the set-up I have
    Just wonder if there's a way round it, there's a echo affect from the TV speakers & the external speakers, most annoying' and when you press the mute button, it stays on the screen:thumbsdow
    the set it's replaced did'nt have this problem
  7. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    1,099
    Coventry
    +83
    Turn down the volume completely instead of muting and you don't get anything on the screen....
    No lip sync probs on mine...
  8. Stormy78
    Stormy78
    Mar 9, 2006
    395
    Birmingham
    +14
    You can turn on the internal mute which means the TV speakers are always off but doesnt display a mute symbol on the screen. You can still use external speakers. I get the same problem and havnt been able to find a way to get both sets of speakers to sync. A minor annoyance thought on a great set!
