samsung picture in picture help
Discussion in 'Plasma TVs' started by hoodga, Sep 5, 2005.
  1. hoodga
    hoodga
    Aug 19, 2005
    80
    is there any way to get the sound on teh small picture?
    i want to play pro ev on my big screen and watch tv in the small bit
    is this poss
    i have it just now like this but i cant reverse the sound
  2. craigae
    craigae
    Oct 6, 2003
    600
    28
    +54
    No, i don't think there is. I guess you're not using a seperate amp for your sound? Cos then, it's not a problem :)
  3. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    How does having a separate amp make a difference?? Could you explain that one to me???
  4. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    If you have a seperate amp and speaker set up you could listen to the tv through the amp.
    So what happens is the main picture is pro evo with the sound turned down on the tv and PIP is set to sky with the sound coming through the amp and speakers.
  5. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    oh i thought he meant sound from both, one through amp and other through tv or headphones. which is what im trying to find out if the pv500 can do it?? i know the 436XDE can
  6. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    yes you can have sound from both, just don't turn the sound down on the tv.
    Then you will have sound coming from one source from the tv and the second source through the amp and speakers.
