Quantcast
Samsung p2270hd cant find freeview channels
Richardmcfc
Happy New Year everyone - hope this is in the right forum.
I bourght a Samsung p2270hd tv/monitor about a year ago, and ever since I have not been able to find freeview channels on the Television.
Instead what I have had to do, is buy a seperate Freeview box and hook it up as a component.
This means that I cant get the HD and also the misses is having a moan about how untidy it looks.
Been trying for over an hour now today - running plug and play again etc - but nothing appears to be working.
Noticed that the television is on ATV, but for some reason I cant seem to get it to digital.
Is this the problem?!
Rodders53
:rtfm: It should be in the manual
Support for P2270HD
You may need to go to the 'Plug & Play' menu to repeat a first time install to tune in the digital channels.
The spec suggests it's DVB-T not DVB-T2 so it won't support Freeview HD except via an external box.
Chris Muriel
I have a P2470HD (same chassis, larger screen); as I recall I just followed the setup guide.
You should both Digital and Analogue options in the "Channel" menu after selecting your country, followed by auto or manual tune.
N.Dean
I'm please that it's not just me who struggles with Samsung stuff. I suspect that they don't test it on a non-tech public.
Some Samsung equipment puts channels in "lists". I think the lists are "Analogue", "Digital", "Data" and "All".
