No TV is perfect. - The same can be said if spending £500 or £5000.
Every time we get a`personal recommendation' or`what the best' or`if I were you' type of the questions, can we remind members of the saying:`one man's meat is another's poison'. We need to construct a profile of your taste for pros, TV use and more importantly your intolerance for specific cons for you to make the right choice. or...you can take the plunge and find out later.
Nonetheless even with all the recommendations in the world, make sure you can demo the TV before you buy it, ideally with your own content in a dark demo room which stores such as richer sounds have. If not, make sure you are able to return the TV if you are not happy with it. Buy from a reputable source!
Please answer the following questions:
- What are your sources going to be? eg - Do you have fibre internet capable of UHD streams? Will you be buying and using an UHD Blu-Ray player? Netflix? Amazon? Catch up TV? HDR consoles? PC?
- SD vs HD vs UHD use percentage? eg 20% 60% 20%
- Movies, sport, console games, PC use (in percentage)?
- How close can you view the TV?
- Do you need to view the TV from the side or only straight on?
- What conditions do you like to view in? During the day? At night with lights on? In the dark?
- What are you currently using and what do you expect by upgrading to a new TV?
- Are you interested in being able to use motion enhancements on your TV to reduce judder and/or reduce motion blur? Both frame interpolation and frame insertion let you do this, read more about it here. They both have their upsides and downsides, so read carefully.
Please rearrange the following PQ attributes, in descending importance:
Blacks
SDR Brightness
SDR Colour Saturation
SDR Colour Accuracy
HDR Brightness
HDR Colour Accuracy
HDR Colour Saturation
Local dimming
How accurate the picture is out of the box (without having to change any settings)
Now for bugs, tell us your possible pet hates related to TVs, in descending order:
Motion Blur
Motion Judder
Temporary image retention
Bad screen uniformity, Dirty Screen Effect, Clouding, Light Bleed, Blooming
Soap Opera Effect
3:2 Pulldown Judder with 24hz movies. See:
Judder-Free 24p on TVs
Loss of detail in dark areas
Reflective screens
Haloing
Colour banding. See:
Gradients on TVs: Color bit depth (warning this is not the same as vertical banding, for
vertical banding see bad screen uniformity)
Now which is most important to you?
Price
Connections
Smart TV (which apps)?
HDR PQ
SDR PQ
Sound
