Anyone have any suggestions for mounting the one connect box behind the tv mounted on a wall? I have a floating shelf setup and stupidly I didnt factor in the one connect box which is supposed to be hidden away rather than placed with the wall mounted screen. At the moment I have all my cables nicely laid out from my old Samsung and dont want to reroute any of them. So I am looking for options to mount it behind the tv on the wall.
I am looking for any kind of bracket or similar box which could fit the box securely. I ahve seen ones for android boxes, apple tv boxes, etc but none of them will fit the profile of the connect box which is 33cm long (ports side HDMI, etc) x 29.5 cm wide x 4.1cm depth UK version.
So far all that I can really see being the best option is just to velcro it to the wall. Forgive the messy photo, I havent cleaned up the uppacking yet. Everything is level and straight but the angle of the photo makes it look otherwise
