Samsung nu8000 series HDR problem
imigix
The tv is operating on full HD well on all sources.
Recently I have subscribed to Amazon Prime and when I view a film flagged as HDR the picture quality is poor, non HDR are fine.
I have looked for adjustments but can only find ones for HDMI inputs on the tv.
Can anyone suggest a cure please.
JayCee
Not all TV's display HDR well.
All you can do is pick a non-HDR version of the movie if available.
maxwell
How are you accessing Prime ?
The NU8000 gives a stunning picture on HDR/4K and has no problems on either Prime or Netflix.
As for TV settings start with the rtings ones and tweak to your liking.
imigix
Thanks for reply, the performance on everything OTHER than Prime hdr is indeed stunning, I have two of these sets a 65 and 75 and both are poor on Prime hdr a third Samsung which is not hdr reproduces the same content on Prime in hd without trouble.
Both effected sets have been set up from the get go as per rtings settings and it seems the only real adjustments there are are for hdmi inputs which are not in use for Prime.
On the effected content there is a language and setting button I thought I may be able to switch hdr off from prime but I cannot even get it to turn on subtitles, of course it may be Amazon at fault.
Having spent a fair amount of cash on these sets which were advertised as hdr compatible I am somewhat disappointed.
maxwell
are you on latest firmware ? just tried the built in app on mine ( I normally use my 4k firestick) with Jack Ryan and Oblivion with no problems at all, also what's your internet speed because if it detects your speed is not fast enough Prime video will drop resolution.
chrissyman
What picture mode are you using?
Foster1984
If all other HDR sources look stunning, this would suggest the issue is related to Amazon Prime and not the TV.
What is it in particular you dislike about the image, when viewing HDR on Prime?
Are the 65" and 75" both set up the same? Is the 3rd set a 4K non-HDR TV or an older 1080p TV?
Have you tweaked the picture settings to match those of the Rtings HDR recommended settings? As I use these on my set, and image quality is excellent.
Which picture preset are you using? As you can adjust the picture for any source, not just HDMI inputs.
I could be wrong, but I don't think you can turn off HDR via the TV's native Prime app.
Again, you mention that other HDR looks stunning, so you know the TVs are "HDR compatible". So I'll assume this statement is just you ranting in frustration.
imigix
Thank you all for replies.
It would appear that I may have caused some confusion in my question.
Both tv's give first class performance on HD and normal expected quality on SD.
On HDR the picture quality is poor it does not get near that of HD, my only source of HDR is Amazon Prime and this is the only source of HDR I have tried.
My picture mode is movies and I use Rtings settings.
Foster1984
What is it about the picture quality that you find "poor"?
Too dark, too washed out, colours wrong tone, etc.
Foster1984
Mainly washed out.
Lastly, is this on all HDR shows on Prime, or just select ones?
You could try reducing the contrast slider, but this might also rob the image of some of it's HDR punch.
Did you say you were using the Rtings HDR settings on the movie preset?
imigix
yes I am using Rtings and so far its on all HDR Prime shows I have tried.
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
