Samsung NTL and MCE
Discussion in 'Cable TV & Virgin Media TV' started by JonMace, Jun 4, 2005.
  1. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    We all know that these STB and MCE do not work well together (dropping digits etc).
    I have read about some US boxes being controlled by firewire the Samsung does not have firewire but does have USB, would it be possible to control channel changes through this and if so has angone done it?
  2. Mike TV
    Mike TV
    I would also like an answer to this I have searched all over to find out what the usb port is for on the back of the box but have found nothing, there is also a distinct lack of manuals available to download for this box that may help. Very frustrated in not been able to get MCE to control the box, complete waste of time if you can't set it to record the correct channel in your absence!!! The only thing I read about the usb port is sombody plugged their IR reciever into it by mistake and damaged the box, so I am reluctant to try plugging anything in there to just to see what happens. I also read the firewire thing it seem there may be a glimer of hope.
  3. spepm
    spepm
    I have gone to the extend of connecting a pulse generator to my IR cable and detecting the responce through a camera to make sure it works. My IR cable works! When I connect to the IR blaster on my computer and then send instructions to it to change the channel it doesn't respond. Since I know the IR cable is working I am thinking that my computer is not sending any instructions to the IR cable at all. What is the USB port all about?
    I don't know what else to try, I have wasted many hours trying to get it to work.
  4. Frosty Predator
    Frosty Predator
    Dec 10, 2005
    107
    +7
    The USB port on the samsung smt-2100c ntl stb is an alternative LAN port to using the more common RJ45. Don't plug anything else in here!!
  5. tpurchase
    tpurchase
    I have MCE and have written a DLL to extract Channel Changes from MCE and send via serial Redeye. At the moment the program only supports a single tuner configuration with serial redeye connected to COM1. I will be writing a configuration tool to allow users to select a different COM port etc. However, if you can support the current configuration, please feel free to contact me.
  6. derrickpetr
    derrickpetr
    May 12, 2006
    24
    4
    Can I use a Samsung SMT-2100C STB (NTL) with a Sony VGX-XL100 Media Centre?
  7. ric9887
    ric9887
    May 27, 2006
    39
    +8
    A good thing is that MS appear to have fixed whatever was broken with their IR box with Vista Beta 2. It controls thr Samsung 2100c nicely, even sending repeated digits.
  8. CyBeRkId2002
    CyBeRkId2002
    Mar 9, 2004
    2,699
    83
    +125
    sorry, a bit off topic but is vista beta 2 mce useable??
  9. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
  10. rmg
    rmg
  11. CyBeRkId2002
    CyBeRkId2002
    Mar 9, 2004
    2,699
    83
    +125
    does this work? anyone had chance to test it yet?
  12. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    The KB fix is for another problem. It will not fix the Samsung NTL STB problem.
  13. Kurt_Wylde
    Kurt_Wylde
    Oct 31, 2005
    461
    +21
    What is the other problem it's for?
    As it seems to describe exactly the NTL STB issue..?
  14. rmg
    rmg
