Samsung N73 or LG LB1DB
Discussion in 'Samsung TVs Forum' started by danbl, Apr 24, 2007.
Tags:
  1. danbl
    danbl
    Nov 5, 2006
    208
    +8
    Well, Ive just had a Toshiba 42C3030D delivered - but it will be going back to JL as Ive found it doesn't have any discrete IR codes and I will be using a Harmony remote with it. It may be petty, and I know it will work in theory - but I cant be bothered with going through the help menu every time it misses a signal, and it being generally slower.
    Ive narrowed it down to the two TVs above, both 799 from Empire Direct (819 with the 3 yr warranty). I would like people opinions on these two sets, ASAP really as I've already been without a decent size TV for 6 weeks (faulty LG set, Currys dragged heels refunding :( )
  2. danbl
    danbl
    Nov 5, 2006
    208
    +8
    Can anyone confirm if these accept 1080p signals - I appreciate it wil be downscaled to native res. I presume the samsung accepts discrete IR codes?
