Samsung Multi Room
Discussion in 'Soundbars, Soundplates & Soundbases' started by fxv300, Jan 15, 2018.
Tags:
  1. fxv300
    fxv300
    Oct 14, 2015
    398
    32
    UK
    +38
    Samsung Multi Room
    Hi, I have a Samsung HW-J500R Soundbar. I would like to add a pair of rear speakers.
    I was looking at the Samsung Sound+ SWA-S9000 Wireless rear speakers.
    According to the spec sheet these are not compatible with my sound bar.
    Is there any similar product I could use. Even just a WiFi amp, I have plenty of speakers.
    Frank
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,829
    The Borders
    +3,535
    What does the Soundbar Manual say about adding additional speakers?
    Joe
  3. fxv300
    fxv300
    Oct 14, 2015
    398
    32
    UK
    +38
    Nothing in respect of what you can add to Multi Room. The app itself (multi room) lists a few options like R5/R3/R1 and R7/R6 also M7/M5/M3/Link Mate but SAMSUNG support mentioned
    Samsung SWA-7000S which I can't find anywhere.
  4. grunty-motor
    grunty-motor
    Dec 26, 2006
    52
    +4
    there is a rather large thread over on the samsung forum about issues with the multi room, which i wish i had found before i bought a pair of R6's to go with my MS650 - low volume output and bad lipsync both of which i get to varying degrees depending on source and format
    so, i would be careful of going down that route if you cant find an answer to your original question
  5. fxv300
    fxv300
    Oct 14, 2015
    398
    32
    UK
    +38
    Thanks for the warning....I shall have a look.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,829
    The Borders
    +3,535
    Rear Speakers and Multi-room are very different requirements!
    Unless your Soundbar has been designed with optional Rear Speakers in mind you are looking at replacing the Soundbar if you want a 5.1 system with wired/wireless surrounds.
    Joe
  7. fxv300
    fxv300
    Oct 14, 2015
    398
    32
    UK
    +38
    Thanks Joe.
