Samsung M87 - VGA resolution problem
Discussion in 'Samsung TVs Forum' started by handsy, Sep 5, 2007.
Tags:
  1. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Hi all, I have a month P7, f/w 2000 of the LE40M87BDX.
    There's no bloomin' 1920x1080 resolution listed as an option in nVidia Control Panel :( I'm connected via VGA (D-Sub) in the back of my Sammy....
    Is this another fault with the panel I've just come across or am I being a n00b ?
    I have an nVidia 8600GT card btw...
    EDIT: in addition when I connect via DVI<>HDMI on HDMI2, I cannot get any audio out of the RCA connectors paired with HDMI2 :( Should I be calling Samsung, or just returning the set ?
  2. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Is anyone else suffering from this VGA resolution issue ? I have a call in to Samsung at the moment, and want to go armed with evidence of a fault.................
  3. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,553
    England, UK.
    +553
    Instead of creating several different threads, why not do a search on the main M8 series thread for nvidia?
    I just did and there are 83 separate posts within the thread.
  4. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Thanks, I do try that - but it is difficult to sift out what I need from such a large thread - I'm sure you'll agree.
  5. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    No problem here, and that's with earlier set with 1010 firmware. 1920x1080 worked over VGA and HDMI 2 with onboard Nvidia 6150 and ATI X300.
    I would start off a lower resolution and refresh and work your way up. It does take a while locking onto the signal, probably 20 seconds (in VGA)
  6. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,553
    England, UK.
    +553
    Not really.
    It doesn't take long to look through 83 posts, especially when they have a couple of lines preview.
    Maybe 10-15 mins.
  7. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Whatever - this is the way I've found I get most response....
  8. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    probably, but it easier to have the one thread with all the faq/infomation in the one place than having to search through lots of single threads many of which are duplicated.
    Curly
  9. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Right, I have a Samsung engineer coming out to view/fix my set next week. It looks like the RCA audio for HDMI2 on my set is broken, plus I have the 1920x1080 resolution problem via D-Sub.
    I'll let you know how it goes after his/her visit.
  10. dpluxor
    dpluxor
    Jan 27, 2005
    64
    I have just bought an M87 also and as I have the 7300GT card, I was also eager to get my PC up and running. I bought £2.50 DVI-HDMI cable off Ebuyer and I have to say it works brilliantly. This is your best method of connection and I am sure you will have a DVI socket on your graphics card. The something weird happened, I could manage to push my resolution up to 1920x1080 as the PC detected the new screen through the cable and let me choose that resolution. The picure was OK but then I decided to change the name of the HDMI2 input to PC and then WOW, a million times better 1:1 mapping, crystal clear fonts etc. Why does changing the name do this anyone ??
  11. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    I posted that a couple of days ago, even if it's set to just scan, it looks better when input is named to PC.
    My guess is that the input bypasses any picture processing, such as colour.
    Would be good if you can do this for HDMI1, I tried naming that to PC too but can adjust colour.
  12. handsy
    handsy
    Mar 9, 2005
    317
    Southampton
    +9
    Wow, so my TV must be knackered then :(
    I can't get JustScan as an option ever - with or without naming the input as PC.......I'll see what Samsung say next week...
    dpluxor, can I ask whether you had any trouble with the RCA audio inputs for HDMI2, as in - they don't work !?
