Samsung M87 V+ Volume Remote Code
Discussion in 'Cable TV & Virgin Media TV' started by Maz21, Sep 15, 2007.
  1. Maz21
    Maz21
    Sep 12, 2007
    27
    3
    Baldock
    +4
    Just spent 90 mins speaking with India!
    I saw the thread re controlling your TV volume from V+ remote control and thought that would be something useful.
    There are 8 codes listed for Samsung on the V+ help section, none refer to specific Samsung models. Spent 30 mins trying each code over and over again, phoned VM, got cut off after 30 mins (they had suggested 10 min wait time!), second attempt spoke to a Scotsman, who after 45 mins put me through to India!
    2 more codes acquired from India, still didn't work, suggested that I contact Samsung! VM don't know what codes relate to which TV!
    Found the code on another website. It's 0079.
    Hope this helps someone!
  2. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    whats this thing with india? why not use the word customer services?
  3. Nivek TT
    Nivek TT
    Feb 27, 2006
    6,565
    Bristol
    +2,132
    You'd have found it on here if you did a search :smashin:
    All the Samsung LCDs for the last 3 years have used 0079.
  4. squaretiger
    squaretiger
    Jun 20, 2007
    i just did & it works a treat. cheers to Kevin & Maz. :clap:
