Samsung M87 remote
Discussion in 'Samsung TVs Forum' started by wolfwiser, Jan 14, 2008.
Tags:
  1. wolfwiser
    wolfwiser
    Mar 14, 2006
    169
    Having searched all over I cant seem to find what I'm after....
    I would like to use the samsung remote to control my sky+ (among others), all I can find is how to control the TV with the sky remote. Does anyone have the code, cant seem to get 031 (sky in the manual) to work.
    Appologies if I'm in the wrong forum.
    Thanks guys in advance.
    :smashin:
  2. Hopalong
    Hopalong
    Jan 11, 2008
    337
    aberdeen
    +21
    Hi mate its 0646 for newish remote and 646 for old remote's,I found the code under older model tv's on the customer services web site after much searching.Hope this helps.
  3. wolfwiser
    wolfwiser
    Mar 14, 2006
    169
    Many thanks hopalong (brilliant name BTW) will give it a go.
    :thumbsup:
  4. paulbrannan
    paulbrannan
    Oct 24, 2007
    130
    +9
    hi,
    tried this with normal sky box built by amstrad but no joy.
    any other codes that might work?
    ty
  5. wolfwiser
    wolfwiser
    Mar 14, 2006
    169
    I have tried both those code but I can't seem to get it to work, I've only recently bought the TV (manufactured october '07) there seems to be a little flash after 3 digits are entered (and the codes in the manual are 3 digit ones).
    I press 'STB' reset (by use of a pen nib) type 646 then power as instructed in the manual. But no joy.
    Am I missing something?
  6. paulbrannan
    paulbrannan
    Oct 24, 2007
    130
    +9
    im presing stb, set, code then flashes but nothing
    make sure the sky box is off when u do this like
  7. LiveLifeGoJump
    LiveLifeGoJump
    Same problem here, I have tried codes 000 - 080 in all for control modes (dvd, vcr, cable & stb) with no luke at all. Contacted Samsung & they said if that doesn,t work then it's a compatibility problem. That doesn't help much.
    Anyone out there managed to control their normal Sky box (or BT Vision)?
  8. LiveLifeGoJump
    LiveLifeGoJump
  9. Hopalong
    Hopalong
    Jan 11, 2008
    337
    aberdeen
    +21
    sorry the code i gave was the wrong one .I gave you the code to make the sky remote work the tv not the samsung remote to work the sky.sorry i dont know the code for the samsung.
