Samsung M405 - hack needed
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Simon Nealon, Feb 1, 2002.
  1. Simon Nealon
    Simon Nealon
    I've just bought the Samsung M405 DVD as I'd read that the hack to change it to R1 was easy, but it doesn't work and I need help!
    I'm trying the following:
    Press Play and Stop on the front panel for a few seconds.
    Enter '1' for English Language seclection.
    Press Repeat on the remote followed by '38767' or '57538' (opinions differ as to the correct code). At this point on screen the current region setting should be shown, but nothing happens! Can anyone help me out as to where I'm going wrong? Anyone else had similar problems? Many thanks.
    Simon
