Samsung m105
Discussion in 'Blu-ray & DVD Players & Recorders' started by colywog, Dec 6, 2001.
  1. colywog
    colywog
    I just bought it and i cannot get the s.fit thing to work i have huge black lines at the top and bottom. Does anyone know how to get this to work?
  2. wattsonp
    wattsonp
    is it a TV or a dvd player?
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,689
    +2,586
  4. phibes
    phibes
    Bought my M105 May 2002. Following hack worked:
    Cold Start
    Ensure tray is closed and no disc inserted
    Press Repeat on handset
    Enter 57538
    02 should appear on the screen
    Press 1, 2, 3, 4, 5 or 6 to set the player to the desiered region
    Or Press 9 for auto-region (even for RCE discs)
    Press Open/Close to open the tray (do all this before 02 disappears)
    Wait at least 15 seconds
    Press standy/power on the remote
    Next time you turn machine on its in the region you set
    Got that above from here:
    http://www.709firmware.fsnet.co.uk/faq.html
    good luck
