Samsung M105 Multiregion Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Ian Davies, Dec 18, 2001.
  1. Ian Davies
    Ian Davies
    Does anyone know of a multiregion hack for the Samsung M105 DVD player? Previous Samsungs have been hackable, so I'm guessing this one is?
  2. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    Ian ...
    Welcome to the Forum!
    I tried to find this out for a friend who has such a player
    There appear to be lots of various hacks for the 105
    but all the ones I have passed on have failed miserably
    So if you do have any luck in your search please update
    this thread so I can pass on the good news !!! Paul :)
  3. Ian Davies
    Ian Davies
    Paulboy
    The website I have found since suggests that the hack is exactly the same as for the Samsung DVD-511 and the 709. Have you heard of this?
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    Bump.
    Anyone have more info on the Samsung DVD M105 hacks?
  5. dhirenpatel
    dhirenpatel
    Mar 25, 2001
    3
    Littleborough, Lancs, England
    Check out DVD Reviewer.net for this hack.
    It takes 3mins to do. The hack works perfectly and is RCE compatible.
    It IS the same as for the 709
  6. phibes
    phibes
    Bought my M105 May 2002. Following hack worked:
    Cold Start
    Ensure tray is closed and no disc inserted
    Press Repeat on handset
    Enter 57538
    02 should appear on the screen
    Press 1, 2, 3, 4, 5 or 6 to set the player to the desiered region
    Or Press 9 for auto-region (even for RCE discs)
    Press Open/Close to open the tray (do all this before 02 disappears)
    Wait at least 15 seconds
    Press standy/power on the remote
    Next time you turn machine on its in the region you set
    Got that above from here:
    http://www.709firmware.fsnet.co.uk/faq.html
    good luck
