Samsung LW26A33W Any Good ??
Discussion in 'Samsung TVs Forum' started by jerkyboy, Jul 2, 2004.
  1. jerkyboy
    jerkyboy
    Anyone got one of these new Samsung LCD's, how does it perform.
    Any problems ?, Light bleed etc
    How good is it as a PC monitor ?.
    Any feedback would be appreciated.
  2. FruitBat
    FruitBat
    Nov 15, 2003
    3,303
    Ealing
    +379
    Yes I've got one.
    There are a couple of threads on this forum discussing this model.
    To summarise:
    My main complaint is not being able to get full-width 16:9 letterboxed in the 15:9 panel (it crops the sides).
    I'm happy with the picture (blacks look black enough to me). Quality does vary with source (e.g. ITV signal on analog & digital is worse than BBC).
    I tried it out with my PC and was impressed. Does WXGA if you've got the right drivers. Games seemed fine.
    At the moment this is still a new toy that I'm playing with. If you want to ask any specific questions or suggest any tests, I'm happy to have a go.
  3. jerkyboy
    jerkyboy
    Does it have component inputs ?.
    Have you tried hooking up an Xbox or PS2 ?.
    Do you get any lip synch problems ?.
  4. FruitBat
    FruitBat
    Nov 15, 2003
    3,303
    Ealing
    +379
    No.
    It's got:
    2 scarts (1 RGB)
    composite
    S-video
    dvi
    vga
    I've only used it with VCR, freeview STB and PC.
    I never got round to getting a DVD player because my last TV was so rubbish. Now I'm trying to work out if it's worth getting something to make use of the dvi (it's all a bit Greek to me at the moment).
    Lip synch: I've only seen a problem once. Channel hopping last friday, I stumbled onto "The Prisoner". What tosh. The sound was slightly out of synch.
  5. jerkyboy
    jerkyboy
    How are you supposed to use the progressive scan feature if it has no component inputs ?.
    Do you know if you could use a component to VGA lead ?.
  6. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    I was gonna ask the exact same question :)
    I assume it'd be component->VGA or component->DVI depending what it's wired to.
    I guess using the 1280x768 computer input will be better than normal WS viewing as the computer will scale to match it and not clip anything ?
  7. FruitBat
    FruitBat
    Nov 15, 2003
    3,303
    Ealing
    +379
    Are you asking me? I'm afraid I'm completely clueless. I got the TV because the Samsungs seemed to have a reasonable picture, had PC connections and this model fitted in the small space that I had available. Now I'm drowning in technology :confused: . I take it that only component or dvi can do progressive scan, or have I misunderstood?
    My PC (bulky and in another room) has a Nova-T DVB card in it and this produced a better picture (correctly letterboxed) on this TV than a Pioneer STB (also picked up a signal on the ITV channels the last few evenings which the Pioneer couldn't). I'm tempted to build a smaller, quieter PC to sit under the TV as SWMBO doesn't like me dragging huge PCs around trailing wires everywhere...
  8. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    No, you can't use a component to VGA lead.
    The DVI-HDCP interface supports progressive scan.
    480/60i, 480/60p, 576/50i, 576/50p, 720/60p, 1080/50i, 1080/60i
    Roger
