I recently built an ASRock H67M-GE/HT with a Sandy Bridge processor running Win7 Home Premium. I connect its HDMI to the HMDI1 port of a Harmon Kardon AVR247. The HK is connected via Component Cables to the Samsung LCD TV.
When I connect the htpc directly to the HDMI input of the Samsung, it works fine. When I connect through the HK, I get "Weak or No Signal". The HK manual says that 1080i signals are passed through to the Component Video Outputs. I'm pretty sure that I need to get the htpc to output the right signal.
I go to the graphics properties in Windows and in Advanced Properties there are about 100 choices for output signals. They look like
1920 x 1080, True Color, 59Hz
The resolutions vary, the color is True, High, 256 and a few others, the Hz are 29, 30, 59 or 60 and occasionally it says "(Interlaced)" at the end.
I tried every 1080 interlaced and every 720 and no luck. Any pointers on what to try next? I'm OK if the answer is buy a new AVR, but if that's your answer, a suggestion will be appreciated.
