Samsung LNR238W
Discussion in 'Xbox Forums' started by Kong, Aug 27, 2005.
  1. Kong
    Kong
    Aug 20, 2005
    360
    is this a US version TV? does anybody know if theres a UK version? this is the HDTV which MS said is optimised for the xbox360.
  2. Tetlee
    Tetlee
    Jan 21, 2004
    19,878
    Taunton
    +4,465
    See what you mean Kong, great reviews but nowhere in the UK seems to sell it :thumbsdow
  3. daddyorchips
    daddyorchips
    Dec 12, 2004
    1,073
    63
    London
    +95
    There's the UK version of that model available widely in 26" and 32" editions. Model numbers are Samsung LE26R41B and LE32R41B respectively. There's also a 23" edition floating around somewhere too I think. Check the LCD forum for more info.
  4. Kong
    Kong
    Aug 20, 2005
    360
    some sites have different specs for the aforementioned monitors. the contrast ratio is 800:1 on some and 3000:1 on others.
    so, you are sure that they are exactly the same LCD panel, just one is for the UK and one is for the US?
