Hello all
My brother in law has an LED Samsunge TV which is fairly new and has a USB port allowing playback of all file types and works with both NTFS and FAT32.
The problem I am having though seems to be with playback of AVI files only. They play fine apart from every so often the picture gets red/green horizontal lines/blobs across it. It appears to be more apparent on a scene change and they fade out after a while.
It's really odd, my first thought was that it would be a codec issue with the TV, however the avi files I have tried are just standard divx/xvid files.
I have attached an example below and welcome any thoughts
Thanks a lot
Thanks a lot
