Samsung LED Problems - Plug and Play
PST
Just bought a Samsung UE40B7020 and started setting it up. I've got Sky+ at the moment (putting off Sky HD until we move to a new house in a couple of months) and the plug and play isn't working.
Sky's hooked up to the television via a scart lead. I turned the television on, went through the steps of choosing country etc and when it got to the plug and play I told it to search for digital and analogue. The search completed without the television detecting any channels and, as such, all I get is snow.
Anyone have any experience of setting one of these up without an HD box?
Oggie
You tried all inputs
PST
I've just tried plugging in just the normal analog television cable and it detected the terrestrial channels on that. It's still not detecting the cable channels via the scart lead (which goes to a dongle to convert it for the tv).
viewmaster
The tv will only see the digital chanels via the analog ariel if you do the install searc both analog & digital listed as cable it will then list all of the signals it sees under the chanel listings it will not see the chanels through the scart lead.!
Greg Hook
Moderator & Reviewer
You've got things a bit confused here. The TV will not 'detect' the channels coming from the Sky box. You just need to change the source to the Sky and then operate the Sky with the Sky remote. You mentioned cable channels, so is it Sky or cable that you have?
