Samsung LED/PC Connection
Tombie
HI all.
Just bought a new Samsung 60 inch LED TV to replace my old 42 inch Toshiba. Previous setup i had when connecting a networked PC to this was DVI-HDMI converter along with audio cables into dedicated HDMI 1 Audio feed on the old TV which worked perfectly.
New TV audio setup seems to be slightly different. Have a HDMI/DVI input which i have plugged the adapter in. Connections on the back are as attached picture.
Just would like to get working, if i need new cables or anything then thats fine.
Thanks for your help.
logiciel
HDMI carries video and audio.
Why are you referring to separate audio connections?
Tombie
DVI to HDMI carries audio? My PC is nothing new and doesn't not carry audio along that cable...
logiciel
I didn't say that.
Don't converters combine the DVI video and the audio into the one HDMI plug?
What was the "dedicated HDMI 1 Audio feed on the old TV"?
The new TV should have some separate audio input that you can use.
