Samsung Led 5 won't turn on
pellumb
I just bought Samsung UA40EH5000R and had problems with the HDMI ports. I tried to upgrade the firmware with one that "virtual_boy" suggested that was for led 5 and led 6 Samsung TV sets and after uploading the firmware via flash disk it turned off and does not go on any longer. I have tried by pushing the exit button for 30 sec, rebooting and holding the power button, key combinations i,e mute+1+8+2+power, mute+2+5+8+exit and none of them works.
Can you give me some help please to get the TV work again?
I would very much appreciate your help
virtual_boy
Can you link to the post where I suggest this firmware for this TV?
I don't recall posting about any TV firmware upgrades, if I did then it was probably quite some time ago and for the LE46A656 which I have.
Thanks.
pellumb
That's true, that's quite a long time ago. My TV set seems to be bricked now but the red light indicator is still on but when I press remote control buttons the TV set does not seem to react at all. If you know any tricks that can help repair the TV please let me know.
I have already contacted Samsung support but they recommend to check with nearest Samsung service center. Because this cases need technician check. Where I live now there is no Samsung service center.
Kind Regards,
Pellumb
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
