Samsung LE52A856S1M Fault
Discussion in 'Samsung TVs Forum' started by barachello2000, Feb 28, 2014.
Tags:
  1. barachello2000
    barachello2000
    Mar 28, 2005
    288
    bangor
    A friend of mine has the above tv, and it has developed a fault where the picture appears to be duplicated on the screen, if that makes sense ?
    I have attached a couple of pics to hopefully show the fault
    Apart from that everything else works fine.
    He rang Samsung support, but all that they can suggest is that something on the board MAY be loose.
    Would anyone be able to offer any suggestions or hints as to possible causes and solutions ?
    Thanks in advance.
