Samsung Le40r74bdx
Discussion in 'Samsung TVs Forum' started by maxbhoy, Apr 27, 2007.
Tags:
  1. maxbhoy
    maxbhoy
    Does anyone recommend this TV ??:lease:
  2. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    i got one last week from currys at £799. Britliant TV. I use it will my PS3 and V+ service. Looks nice on and off!Only drawback is that theres only one HDMI input but i bought a 4 way switcher and all is good now!
  3. maxbhoy
    maxbhoy
    Cheers waring192
    I don't need a TV for freeview as I have cable is their any others TV's
    you would recommend around this price and size ??
    Thanks Again :thumbsup:
  4. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    to be honest i couldnt find any better ones which look physicaly as good. AS far as specs go its very good, 5000:1 contract is briliant. Forgot to mentionion the sound it not very good, but if you have a amp for films then its perfectly fine, i mean if you mostly use it for general tv then its fine but for movies and consoles then its not brill.
    If you shop around you mgiht be able to find the newer model for a tiny bit more, i think the only diffrence is that it has 3 HDMI inputs.
  5. maxbhoy
    maxbhoy
    Thanks again for your input. :thumbsup:
  6. tsutton
    tsutton
    Apr 1, 2007
    137
    +4
    If you still haven't ordered it yet, you can get it for £699.99 with free delivery via Play.com - that's what I did 2 days ago, should be gettung it soon. :D
  7. MrMister111
    MrMister111
    Nov 23, 2006
    5,748
    UK
    +141
    I bought the replacment for it the LE40R87BDX, its got 3 HDMI's, better processing technology, and has great SD and HD PQ.
    I hummed and ahhed about whether to get the R74 or spend a little extra (£800) and get the new (just out in March) R87, glad i did now.
    The R74 has been out a while, my R87 is the new version so will have newer generation panel,, better technology, better connectivity etc, all for a little more than the R74.
    Which ever you get though I think you'll be pleased I am!! :smashin:
  8. MrMister111
    MrMister111
    Nov 23, 2006
    5,748
    UK
    +141
    Have you ordered yet? which did you go for and why? how much did you pay?
    cheers
  9. sTaD
    sTaD
    Sep 18, 2006
    168
    +3
    Whats settings do you have?
