Question Samsung LE40R74BDX/XEU Resited now wont work
Rob112
Hoping for some generous advice.
Had a Samsung LE40R74BDX/XEU version SP01 for several years without a hitch. Just moved TV to another house and turned it on. It comes on and I can navigate settings etc but the box to select channel tuning or plug n play is greyed out so I cant get any channels or tune the TV in any way.
Tried new power aerial, no change.
Any tips greatly appreciated.
Rob
JayCee
I believe that model has a separate DTV menu for tuning/setup after selecting DTV with the TV/DTV button on the remote.
JayCee
Use the source button to select TV.
On the correct/original remote that was supplied with the set... BN5900516A
“TV/DTV” above the “Rew” button then use the “D.Menu” button to access the Freeview tuning/setup menu.
Rob112
I am pleased to report that the problem is sorted thanks to JayCee advice.
Couldn't see the woods for the trees!!
Found DTV button and reprogrammed.
Thanks very much. Rob
