samsung le40r74bdx power prob
dieseldod
hi lads hope you can help me out on this one, the above tv when you insert the power lead the relay sounds once and the unit continually switches on/ off. you dont need to touch remote.you only hear the relay once when the power is first applied. the screen stays on for a second each time and there seems to be a large square on top left of sceen that is not black but different coloured lines.i changed the four 10v capacitors to 16v while i was in there and of course no change as the capacitors i removed were good. any if on this problem will be gratefully recieved, thanks in advance
