Samsung LE40R51BX or JVC LT-37DS6
Discussion in 'LCD & LED LCD TVs' started by saurabh123456, Aug 19, 2005.
  1. saurabh123456
    saurabh123456
    So which lcd shall i buy?
    This
    [​IMG] or [​IMG] this.
    The tv will probably be used for watching sky tv (SKY HD as well) and dvd's from Panasonic SA-TM1 DVD player (home cinema kit). So i am looking at(in preference) 1) picture quality 2) Screen Size/Value 3) HD.
    If there are other LCD tv's suggestion within the same price range those are welcomed too :thumbsup: pls help!!!!!
    thx
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    JVC for me, every time. Samsung's are nice and a decent brand, but Sharp/JVC/Panasonic are a notch or two above. Possibly Sony included as well.
    Don't think the 3" is going to make any difference other than playing a numbers game.
  3. ElectroPhobia
    ElectroPhobia
    After an extensive search, I've decided on the JVCLT37DS6. I was well impressed by the set and having spoken to a number of salesmen in different stores as well as reading various reviews I am satisfied that this is the one for me. What's the best price you found?
  4. saurabh123456
    saurabh123456
    what about philips?
  5. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    Least said about Philips and I the better! Others think they are good products - but I suggest you use your own eyes and decide for yourself which looks best to you. After all, you're the one having to live with whatever you buy, and you might see or not see things that we do or don't.
  6. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    The 7320 series from philips should be nice, but i would take the jvc, it's a great all rounder!
  7. saurabh123456
    saurabh123456
    i would do it but all the stores have crappy pq on tvs as they split teh signal, so there is no way i can see 4 myself. Also, i can't ask the store to play a dvd cos 1) big store, more ppl, less staff. 2) and i am not buying from that store so they won't be very happy after me testing all their lcd panels and then deciding to walk out :eek: :hiya:
  8. saurabh123456
    saurabh123456
    can't find it in the uk (etailers and retailers) :(
  9. saurabh123456
    saurabh123456
    £1646 inc del from price runner
  10. Yaka
    Yaka
    Dec 20, 2000
    1,676
    2
    63
    +114
    does the 40" samsung suffer from tearing probs?
  11. guypb
    guypb
    Jul 13, 2005
    105
    16
    Samsung now available at Currys - looks great - loads of inputs and price at pricerunner looks excellent.
    My main concerns before committing the the 40" Samsung are:
    Resolution - this isn't 1920x1080 - does it really make a difference?
    Price - are they going to plummet - or are these online offers really good value as these appear to be 1st Gen large screen LCDs?
    (BTW there is always a theory that one should buy 1st Gen products as they tend to last the longest!)
