Samsung LE40R51B only 1 rgb scart why!!
Joined
Dec 15, 2004
Messages
6,477
Reaction score
1,653
Points
1,420
Age
53
Location
lancs
i have the samsung LE40R51B and it has 2 scarts but only 1 is rgb, is that the case with all manufacturers or is it just samsung who do this ,is it more costly to do rgb or is it just bad planning on samsungs part?
i love:spam: on milk roll with cherry tomatoes and kettle crisps!
I think its down to costs! I have a Sony with 3 scarts of which only one is RGB!!
:eek:
Out of curiosity, what do you want to plug into 2 RGB inputs? Not saying you're wrong to complain, just wondering what people use them for.
I've got 3 devices which have RGB as their best-quality connector:
Sky+
Humax 9200T
Panasonic DVD recorder
The Sky+ and Humax are daisy-chained, but the Panny has to make do with S-Video.
I have Samsung LE40R51B which I connect PS2, Sky + box and dvd player to RGB scart by using a switchbox, check Keene electronics, they have a selection.
Do you use a manual switchbox, or a remote controllable one?
I control everything with my Pronto, so a manual switchbox is a no-no.
It is a manual one, although Keene do a nice one called Vivanco which looks good.
i run my sky though my rgb input.
if i daisychain the dvd throught the sjy box, what do i have to press on the sky remote to access the dvd?
i tried it and simply switching the dvd on while watching sky doesnt work
When I tried daisychaining something through my Sky+ SCART, I found that the 'source switching' thing didn't work. ie. The telly didn't automatically switch to the device.
You have to make sure that the Sky is 'off' and then manually set the telly to the appropriate RGB scart input (usually scart 1).
Personally, I daisychain the Sky through my DVD player which works wonderfully. Though it's quite an old deck and it seems that many modern players have dropped the twin scart feature.
Gav
The signal from the DVD player should override the sky box automatically, as soon as you switch the DVD player on. If it doesn't, two things to check:
Is the scart cable from the DVD to the sky box fully wired? some scart cables do not have the necessary wire to enable auto-switching (pin 8, IIRC).
Some devices have an option in the menus to enable/disable scart control. Make sure it's turned on.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
