SAMSUNG LE40M87BDX mapping HDMI to channel buttons
Discussion in 'Samsung TVs Forum' started by tuckeratlarge, Jan 12, 2008.
Tags:
  1. tuckeratlarge
    tuckeratlarge
    Dec 22, 2007
    5
    4
    I have a SAMSUNG LE40M87BDX and I want to map the HDMI inputs to the channel buttons on the remote. As in button 0 for HMDI 2 and button 9 to HDMI 1
    So I would have it like this....
    1. BBC 1
    2. BBC 2
    9. HDMI 1 (Xbox 360)
    0. HDMI 2 (DVD Recorder/SKY)
    Then I don't have to fanny about with remote for the TV I can just use the sky remote to select the channel I want.
  2. fingers mcginty
    fingers mcginty
    Is this possible?...that would be so handy!
  3. sdu1975
    sdu1975
    Mar 12, 2005
    889
    Sheffield
    +18
    I've an F86 and if possible would be cool:thumbsup:
  4. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Or you could just buy a remote with discrete input functions- considering you've just spent £1000 on a TV another £100 on a quality remote that'll replace all your others, plus having discretes is worth it.
  5. tuckeratlarge
    tuckeratlarge
    Dec 22, 2007
    5
    4
    What do you recommend?
    discretes?
  6. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    I know the URC MX-850 has discrete codes for this TV, as I have that combo myself. Not sure about Pronto line. On the URC database there are discretes for
    DTV
    Air
    HDMI 1, 2 & 3
    SCART 1 & 2
    Component
    VGA
    S-Video
    16:9 and 4:3
    Power on and Power off
    Discrete IR codes are specific to that command, ie rather than you doing INPUT-INPUT-INPUT-INPUT to reach VGA, just press VGA button on the remote. Or have a macro, so for "Play Xbox" you have
    TV power on
    AV amp input #1 - Xbox
    Delay of 10 seconds (for the TV to switch on)
    TV VGA
    So you don't have to do a thing. No need to fiddle with your amp and TV remote, pressing 3 buttons on two remotes.
  7. tuckeratlarge
    tuckeratlarge
    Dec 22, 2007
    5
    4
    Great - thanks for the info, I will look into this universal remote stuff.
    But hey, anyone got an answer for my original question?
