Samsung Le40m51bx
Crumpets
Hello, have a quick question and hoping somebody on here will know the answer. Basically I have the Samsung LE40M51BX/XEU and called Samsung about six weeks ago after reading on here about updating the firmware fot it, the lead and disk turned up but am a little worried as the disk has the Rome flash setup on there and it states that the upgrade is for the LE40F71BX/XEU TV?
Is this the right firmware or am I about to cause my TV to explode if I do the upgrade?
Have put the upgrade doc header below in case it helps...
Model: LE40F71B, LE46F71B
Subject: Software upgrade for 1:1 Pixel Mapping via HDMI input.
Contents of disc: Rome Flash Setup.exe
Justscan Upgrade.doc
T_FMSLMPEU_1009SVC.mot
Install the “Rome Flash Setup.exe” file to your Laptop/PC by double clicking the file from the disc.
Any info much appreciated.
S
shrubster
I also have a Sumsung TV and have heard of the updates you can do, but no one i know has managed it.
.... to be honest i would be tempted to get back in contact with Samsung and double check the stuff they sent you is right......
......If you do manage to update it i would be interested to know the results..... :smashin:
