Samsung LE40F86 and Samsung HT-TZ315R setup help
Discussion in 'Home Cinema Buying & Building' started by Icecoolally, Feb 10, 2009.
  1. Icecoolally
    Icecoolally
    Feb 10, 2009
    4
    Have just ordered the HT TZ315R surround sound and was hoping someone could help me in what cables to use. I plan to add a PS3 also to my setup in the future. Just need advice on what types of cables to use to get the best sound and picture. Cheers guys
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    2 hdmi cable(1 until you get a ps3), and 1 optical cable.(for when you get a ps3).
    and thats it.
    pretty straight forward really.
  3. Icecoolally
    Icecoolally
    Feb 10, 2009
    4
    will i still get 5.1 sound with an hdmi cable from tv to surround sound unit
  4. Deputy Dawg UK
    Deputy Dawg UK
    Jan 9, 2006
    1,478
    Rushden, Northants
    +58
    Mate,
    I have just posted my problems with this in the 'cables section' I am hoping someone can help me too ..............:):)
    All,
    i have recently bought a SAMSUNG HT-TZ315R cinema system, replacing an old Sony DAV 500..... Problem.....I had optical lead going from my Sky HD to the Sony then optical from my ps3 to the Sony.... There was only one optical inpput to the Sony so I used a splitter which worked perfectly....(had to ensure one system was off before using the other)
    Now with e Samsung tried the same set up..No sound..Sound works if I go directly either from the PS3 or Sky but when I use the splitter there is nothing....
    Is it the splitter ? are some better than others ?
    Is it anything to do with the Samsung 315R ?
    Am I better off getting off getting a switch ?
    Hope someone can help
    Kevin
  5. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    no, your tv doesnt use hdmi as an "out" only an "in", so its really just for video into the tv from a source, not for feeding audio or video out to a surround.
  6. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    just buy a cheap optical switch..or open up the splitter, as it may be a bit "off",or somethings damaged it.
    you are making sure that only 1 thing is on at a time, and that the cables are seated correctly?
  7. Deputy Dawg UK
    Deputy Dawg UK
    Jan 9, 2006
    1,478
    Rushden, Northants
    +58
    Thanks Mate,
    Yeah my Harmony sets it all up so turns the necessary things off....Possibly the splitter is damaged just got another one so i will give it a try..if it doesn't then may look to getting a switcher...thanks anyway buddy....
    kevin
  8. Icecoolally
    Icecoolally
    Feb 10, 2009
    4
    Right so what do i need then . And please no more thread hi jacks .
  9. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    i already answered your post last night :
    ^^ that last part, to clear it up - you will get 5.1 surround sound from any movie you play on the 315, from its speakers, and you will get video when you connect hdmi to the tv, but you will get no audio back from hdmi,from the tv, so if you want to connect the tv,for tv audio through surround speakers, then use the tv's analogue phono audio outs, to the surround system,for STEREO audio only..it doesnt pass 5.1 from the tv's optical or phonos,only stereo.
  10. Icecoolally
    Icecoolally
    Feb 10, 2009
    4
    cheers guys
