CarlosAdams
I've recently purchased the 686...The picture is lovely and the 100hz makes the picture incredibly smooth. SD broadcasts dont look bad at all, I use it for my playstation and the picture is just awesome. However I do have one gripe. When I watched a Blueray movie the other day I noticed that the picture would ever so slightly flicker every now and again. When I say ever so slightly I mean that its not something that most people would notice. However, I do and its very annoying! I saw it once I couldn't stop seeing it!
I not really sure what could be causing this. Playstation? I borrowed an brand new Blueray player from my friend and got the same result. I did various tests to see if occured at the same point on the disc on BOTH players and it didn't. In fact I think the playstation was slightly worse. Incidently there are no issues with the SD picture which is delivered through a coax direct from the aeriel. I also watched a normal DVD through the Playstation but couldn't see it happening?? I'm not sure if its a problem with the TV or may be even some kind of power issue (power spike?)that is affecting the picture as my Amp, Sub, Playstation and TV are all plugged into a bog standard 4 way splitter running from one socket. As for the HDMI cable, it's a fairly expensive but not top of the range. Can some body please shed some light on this? Maybe give me some tips on how I would go about isolating the problem
