SAMSUNG LE37R88BD connection to PC
pep411
I am a total novice in terms of cabling gadgets. I have purchased SAMSUNG LE37R88BD.
Following is the connections info
3 x HDMI Connection/s
1 x S-Video Connection/s
1 x Component Video Connection/s
1 x Optical Terminal Connection/s
1 x Headphone Socket
2 x RGB Scart Connection/s.
Can somebody please suggest me with links, as to which cables will I need to connect my Mac Mini to my samsung lcd tv.
Mac min connection info....
Audio
* Combined optical digital audio input/audio line in (minijack)
* Combined optical digital audio output/headphone out (minijack)
Please suggest me your opinions. I am looking at purchasing a 5m HDMI-DVI cable from ebuyer ( £5.83), a good purchase. Is this any good or other method would be better.
Thanks in advance.
davepuma
I would imagine that your TV has analogue audio inputs (red/white in) so buy a 3.5mm to phono cable and that should do the trick. See HERE. Just connect that to the headphone output on the mac mini.
pep411
thanks for your reply.
Mac mini has digital optical audio input provision. Is this anyway superior to the headphone jack output.
davepuma
Technically yes, but you have nothing to connect it to. The TVs optical connection is an output, same as the mac mini. To utilise the optical connection you would need an av receiver or surround sound system.
