Samsung LE37R87BDX Digital Channels
Discussion in 'Samsung TVs Forum' started by bigfish808, Feb 12, 2009.
Tags:
  1. bigfish808
    bigfish808
    Apr 21, 2007
    10
    I've had the Samsung LE37R87BDX for going on 2 years now but always had Sky so had no need to use the built in freeview.
    I recently got rid of sky so decided to use the freeview on the TV.
    Having a big problem though! Everytime I turn the TV to standby and turn it back on I lose all the channels!!
    The channel list is still there but just get "NO SIGNAL" on screen and need to re-scan a couple of times before they come back.
    I searched the forum to see if anyone was having similar problems, Only thing I came up with was that it may have been in shop mode, I checked this and changed it to home mode and ran the "plug & play" through but the same thing happened when i turned it off!
    If anyone could help I would greatly appreciate it.
    Cheers!
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    is it all the channels it looses analogue and digital or just the digital(freeview) channels it could be you need your aerial and signal checking.
    Curly
  3. bigfish808
    bigfish808
    Apr 21, 2007
    10
    It's just the digital.
    Don't get a particularly good picture on the analogue either.
    Once I've re-scanned the box a couple of times and found the channels again it has at least 75% signal showing?
  4. bigfish808
    bigfish808
    Apr 21, 2007
    10
    Any other suggestions?
