Samsung LE37R8 PIP
Discussion in 'Samsung TVs Forum' started by gerC, Sep 15, 2007.
Tags:
  1. gerC
    gerC
    Can anybody help me please ? I just bought a Samsung LE37R8 Television and I cant seem to get PIP to work for me :confused:
  2. gerC
    gerC
    Picture in Picture.
  3. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    What do you mean you can't get it to work? You need to give us more information on what you're trying to do.
    Just beware you can only use PiP on HD sources, and the picture window will only show sources from SCART or Composite inputs. You can't for instance show 2 HDMI sources, with one in a window, or VGA source with HDMI in a window. Check the manual for the table of PiP acceptable combinations.
