P
pseudo7
Hey all,
Not sure if this is this is the correct place to put this question but i did a search with no avail.
I was wondering if this set-up would work:
Source (DVI + Audio out off a macmini) -> Change the DVI To HDMI and leave the sound cable as a standard cable (3.5mm jack? the same as headphones) then plug them both into a Samsung LE37A559P.
Would i get the sound and the video from both cables at the same time or would i just play a silent video or blank screen with sound?
Many thanks
Chris
p.s. you may notice i'm new to this forum (seems very good) so please be gentle!
Many thanks
Chris
