Samsung LE32R88BD is crap
Discussion in 'Samsung TVs Forum' started by Hixxey, Jan 14, 2008.
Tags:
  1. Hixxey
    Hixxey
    Nov 17, 2007
    Just got this TV today and after endless messing around with the settings in VGA, Component and Scart settings I have decided the TV is crap.
    All outlines have a 'meshy' edge and its even more noticable in component mode.
    I thought there might be a setting to stop this but I can't find it. This tv is going back tomorrow.
    What TV is the best for Xbox 360 and Sky HD for around £500?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Well something seems a miss, as that TV gets great reviews.
    I assume you have SKY or SKY+ currently just make sure the picture settings on the SKY box are RGB not Pal and 16:9 not 4:3 and you are using a quality SCART Cable, not some supermarket "Gold" cable.
    As for the XBOX you have set the aspect correctly (16:9)? and if going via component set to HD out (i.e. bring the res up) as that is a common failing I see a lot on this site.
  3. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    To check the quality of the set tune in Freeview.
  4. Hixxey
    Hixxey
    Nov 17, 2007
    Thanks for the reply but the crappy image seems to be in the menus aswel. Its not just the connections its the built in menus that have fuzzy edges. :thumbsdow
  5. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    So what is the picture like in Freeview (BBC1)
  6. Hixxey
    Hixxey
    Nov 17, 2007
    Poor. Freeview was always going to be poor but it still has these dotted lines instead of normal lines
  7. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Take the TV back and complain then.
    Out if interest why was freeview always going to be poor, it either works or does not due to a bad aerial.
  8. M_Infinity
    M_Infinity
    Feb 11, 2007
    105
    Hi mine was exactly the same, the 360 looked terrible via component and in Vga mode there was weird outlines around everything. I did post up on here about it a long time ago but people that responded with the same tv didn't seem to have the same problems. The blocky menus you refer to are the same on most tv's though I think? I've just brought a Toshiba 47" Z series and they are just as blocky as the Samsung.
  9. Hixxey
    Hixxey
    Nov 17, 2007
    What did you do with your Samsung then?
  10. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    @ Hixxey: have you had a look in the R86/87/88 optimal settings thread lots of good settings you can use, turn off movie plus on all inputs this is probably whats causing the meshy edges, if you send the tv back and "want the best" your going to have to up your budget for a Panasonic or a Sony.
    Curly
  11. Hixxey
    Hixxey
    Nov 17, 2007
    Tried them all. No good at all
  12. tvdavid
    tvdavid
    Feb 20, 2006
    2,605
    North Essex
    +120
    I am getting the Samsung LE40R88BD but hope I dont get this problem with my set.
    The menus seem fine on the Samsung TV I have now and there not blocky at all.
  13. Hixxey
    Hixxey
    Nov 17, 2007
  14. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
  15. JDM121
    JDM121
    the r88 is rubbish no doubt about it man
  16. Hixxey
    Hixxey
    Nov 17, 2007
    Thats what I am coming to believe. Why do you think this?
  17. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Would you care to elaborate, a sweeping statement such as yours helps no one.
    Curly
  18. WalkInMyShoes
    WalkInMyShoes
    Jan 20, 2008
    1,321
    +78
    tell me more, Im thinking about buying one of these. as curly said just a general "its rubbish helps no one"
  19. bikesteve
    bikesteve
    Oct 5, 2009
    4
    i bought a 40"samsung lcd from tesco's after 13 months the picture started flickering the only way to stop it was to turn the backlight off this made picture quality very poor.
    contacted samsung they were not interested as it was out of warranty,contacted tesco's and after a lot of persuasion they agreed to get it repaired as a goodwill gesture (according to the sale of goods act 1978 a large electrical purchase should last about 5 years before developing any faults, although this is only a guidline) anyway the tv was repaired in jan this year and now it has gone again when you switch it on you get sound straight away but picture takes about 4-5 mins to come on then it flashes for about 5 mins even with backlight off i will never buy another samsung appliance i have tried asking samsung about the fault and they just say they can send an engineer to check but it will cost me i don't want to pay for a repair only for it to go again in a few months time tesco's say they will not repair it again either
