Samsung LE32r88 Easy question
Si_B
Hi iv got some sort of problem with my lcd but I had a look around the hidden menu thing when I first got it. Does this void the warranty even if nothing was changed?
mitchb
On the previous le32r model it was
turn the tv onto standby
info
menu
mute
then turn it back on
Might or might not work, worth a try
Si_B
Sorry my question was. I'v been into the menu and was wondering if it voided the warranty as I need to send it off for repairs.
KUBBY
You dont say what the problem is that caused you to view the service menu ?
I dont think that just viewing that menu is going to void your warranty at all.If it has to go back,I wouldnt mention it.
Si_B
Well the left side of my LCD is brighter than the right. So don't think its a problem that can be solved unless sent off for repairs.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
