Samsung LE32R8 - FLASHING RED PIXELS
NatterJack Toad
Ive just bought the new Samsung model for £800, and I've noticed that on occasion there are flashing red dots on the screen. Usually in a vertical line.
This is my 2nd Samsung which has had the exact same problem so Im not sure what is going on?
Is the TV f00ked? Is there something else it could be?
Blackbolt360
Where on earth did you pay £800 for that???
Its £599 in most places and you can get it cheaper with discount codes at dixons/currys for as little as £535.
Get a refund immediatly and get one for cheaper, use the problem with the pixels as an excuse.
D
Devil86
I ve got the same problem.
The line of pixels appears in the middle of my TV (LE32R86 MODEL S)
It's not every time. It can be don't appear during long time and then, i can see it !
Does it need à remplacement ?
ps : sorry for my english i am french
D
Devil86
I think the problem appears only when you have a VGA periph. plug in
A
Anti-static
I had exactly the same problem on my 32R88. The line of pixels ran from top to bottom about 6 inch from the left. I you freeze the picture on a dark backgroung then it is obvious.
I called Dixons helpline and they sent a replacement without any questions.
The replacement arived yesterday and it is a far superior picture. Both screens were/are Sp03. Maybe it's a psychological thing! :)
D
Devil86
When the red pixels appears, just turn OFF the TV.
Turn ON and miracle those pix's are go away ! :thumbsup:
Do u think it need a replacement ? This is the only bug i have with this TV !
A
Anti-static
Well that didn't cure mine. I switched it On and OFF loads of times and it made no difference.:rolleyes:
dchris2
yeah i was getting a column of red pixels flashing on the left side of my set but they went away after I switched it on/off.
I have some other issues with this set I don't know if you noticed that if you chenge the status of hte DNR (OFF, LOW, MEDIUM, HIGH, AUTO) on ext1(or any other input) it will change it for all inputs
Also there is some banding especially in darker tints, if you are a virgin customer look at channel 0 at the logo of Virgin do you see any banding near the dark areas of the logo? Please can you check to know if this a global prob with the set or just mine.
D
Devil86
Yesterday, the TV was turned on during 15 Hours and no red pixels comes !
I don't know if the pb is solved....
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
