Samsung LE32R74BDX LCD - Is it NTSC compatible??
M
MaxTraxx07
Hey everybody, anybody,
I need some help :lease: I know that the majority of new Tv's are NTSC compatible, but can anyone tell me if the samsung LE32R74BDX is compatible or not. I've been searching the net high and low but can not get a conculsive answer and as for the manual, well let's just say the spec's page was a little under specified really NEED HELP.....as i'm planning on getting an American PS3 don't ask why :rolleyes: but :lease: does anyone have an answer!!
MaxTraxx07
Blackbolt360
MaxTraxx07
Yep it is. My xbox 1 is NTSC. If you are getting a PS3, run it through HDMI anyway at 720p and you will be fine. HDMI isn't region specific, its a single unified output.
Coldgunner
Established Member
US ps3 will be fine, with HDTV ntsc and pal is not an issue colour wise, and your tv should support 60hz, I have the 26'' samsung and its fine. I have ps3 running into it via HDMI at 1080i, wii is plugged in via component running at 480p EDTV 60hz and thats fine too.
🎬 Poirot 3, Spider-Verse, Psycho Collection & Mask of Phantasm 4K + best/worst animated Batman
Back
