Hi all
I have just bought a dvd upscaler, a samsung 1080p7 to go with my sammy le32r73bdx tv. the dvd player works fine thru scart, but when i connect the dvd player up to the tv using a hdmi cable, it doesnt work.
while connected with hdmi, if there is no dvd in the drive, the menu screen comes up and i can have a look at the settings etc, but as soon as i put a dvd in it loads and then i get a blue screen and nothing else, i have left it for a while and nothing changes.
I also have a 26 Inch version of the same tv and i have tried the dvd player on there with the same hdmi cable and it works fine.
anyone have an ideas how i can fix this? is this someting that can be fixed thru a setting or something? or is the hdmi port on the 32" tv broken??
I have alos just performed a reset on the tv, using the service menu, but still a blue screen when the dvd should start
many thaks for any help
